SPEC Comparison: Stage 2 PLUS vs. Stage 3
Old 09-25-2005, 08:37 PM
JoeyAnderson's Avatar
Question SPEC Comparison: Stage 2 PLUS vs. Stage 3
For those that do not know, Stage 2+ is different from Stage 2. Instead of replying to this thread, check out http://www.specclutch.com
For those that have experience with both: What would you recommend?
This is going to be a street driven, cam-only nitrous car, no hard launches at the track. Mostly runs from a slow 1st gear roll. This is not my daily driver.
I presonally have no experience with either clutch, but I need to order one this week.
What are the ups/downs of both? Which would you recommend for my application?
Old 09-26-2005, 10:18 AM
Bigrob339's Avatar
would be kewl if anyone had any info, i am looken for a clutch, mine is stock now, thank god i have street tire or it would be slipping, but it isnt yet but i dont give it very much longer.
thx rob
Old 09-26-2005, 10:22 AM
Vax
Vax's Avatar
the stage + clutches are designed to have better clamp power and still retain the feel of the said stage clutch.
redline2k's Avatar
I had good luck with the stage 3 with cam only and a 100 shot, but when I went higher on the spray it started to slip, and if you do plan on ever running slicks I wouldn't use either clutch you listed.
