cam install???
Yeah, what Ellis said. Scoggin Dickey has all that stuff at pretty good prices. They also sell Manley 1423 springs (which would be the min spring I'd run on that setup) for around $75 less. But the Patriots are duals (piece of mind). And IF you plan to run it to it's peak rpm level, I'd consider some new rocker arms too. The stockers are fine until you start living above 6500. Then those needle bearings scare me.....
