How to !air tubes
Old 09-26-2005, 09:12 AM
SS Aleks's Avatar
Default How to !air tubes
I want to remove the air tubes and valves, from the exhaust system. Do I just remove the parts and block off the vacume lines? I did this with my old lt-1 and the computer tune took care of any engine codes I just wanted to know if the LS is the same way.
Old 09-26-2005, 09:30 AM
777's Avatar
You wil have an ses light, but it won't mean anything. You can get it deleted with ls1edit or hptuners.
Old 09-26-2005, 10:00 AM
NLinnear's Avatar
Also pull the fuse for the air pump.
Old 09-26-2005, 10:08 AM
NviouSS's Avatar
i never pulled mine out and haven't had any problems.
Old 09-26-2005, 10:09 AM
fugasi's Avatar
I ended up just removing everything from that system (pump, lines, etc) and my headers don't have emmissions provisions... Codes were removed with tuning...
Old 09-26-2005, 11:47 AM
SS Aleks's Avatar
Thanks for the replies. The hedders are from SLP so they have provisions for the tubes, I just have to make a couple of block off plates for the hedders.
Old 09-27-2005, 04:20 PM
Bill Bowling's Avatar
Talking
I never pulled mine. Is it marked? I will check and pull it.
Bill
Old 09-27-2005, 04:29 PM
RedWS6 00's Avatar
I remoeber allt he AIR pipes when doing the LSX intake install, the vacuum part that the air pump goes to was getting in the way. Removed all apart fromt he Air pump int he front drivers side fender, may remove that at the weekend.
I ran the car with the AIR fuse still in place for a few days, its a little noisy when you start up, hearing rushing air under the hood, sounds like something is wrong, or you have a vacuum cleaner plugged in under there.
The pump is feels quite high pressure when you put your hand over the pipe that goes nowhere, there must be some weight in the pump, so out it will come at the weekend.
Also removed the EGR at the same time. I used HP Tuners to delete the error code.
Old 09-27-2005, 04:34 PM
frisky2101's Avatar
where is the fuse for the air pump ? I already have the air pump, all the lines and the egr removed as well as the pump. Headers are capped and programs were removed when fastech did the tune.. But I haven't found the fuse yet need to know where it is
Old 09-28-2005, 02:38 AM
RedWS6 00's Avatar
I expect your fueses are in the same place as mine. Under the hood you have two fuse boxes, well one is mainly relays. There is a relay for the AIR pump but it kept it in for safe keeping, I know if I remove it I would never find it again, however i will never need it again. Anyway, I removed the fuse from the fuse box, as shown in the photos. Hope this helps.
Attached Thumbnails How to !air tubes-air_fuse.jpg   How to !air tubes-fuse_boxes.jpg
Old 09-28-2005, 02:08 PM
frisky2101's Avatar
thanks
Old 09-28-2005, 09:32 PM
SSDoubleK's Avatar
What kind of HP gain can you really get from removing the air tubes and pump? Got me thinkin of removing mine also.
Old 09-28-2005, 09:36 PM
fugasi's Avatar
Negligible... The AIR assembly is typically removed when you get rid of your cats, not for a tangible HP gain.
Old 09-28-2005, 09:38 PM
brad8266's Avatar
no hp gain, just the convienece of it not being in the way. By the way, has anyone got hit up for removing their AIR on inspection?
Old 09-30-2005, 10:46 AM
Talking
It sure cleans up the engine bay. Mine passed inspection last year. Due again in Dec. I do not think we have a visual just ODB2 hook up.
Bill
Old 09-30-2005, 10:56 AM
Talking
It sure cleans up the ehgine bay.
Bill
Old 09-30-2005, 06:08 PM
Moderator
davered00ss's Avatar
Nice engine bay. Some Billet fuel rails would look killer in there too.
