how much for 4l60e
LS1TECH Sponsor
how much for 4l60e
How much is a built tranny 4l60e worth only thing burnt out is the 3/4 clutches. The parts it has are listed below. Trying to see how much I should be trying to get for this. This was on my turbo car I blew 3/4 like nothing........Ill be going another route..........so trying to see how much this should go for opinions......becuase Im not really sure or would it be better to just put the new 3/4 in and sell it rebuilt? btw this is the kit from pro built transmissions
The HD sleeve & piston for the input drum is included. The vacuum modulator
provides instant downshifts & extends the life of the 3-4 clutch pack.
"Complete description of the parts in the rebuild kit"
"Front pump"
Seal retainer
Late design seal
10-vane rotor w/vanes & slide assembly (higher volume than 13-vane setup)
Trans-Go steel rings & priming spring (over 5,500 rpm)
New replacement stator support
"Clutches, Steels And Pressure Plates"
4 Borg-Warner reverse/input clutches .068
4 Reverse/input "low drag" Turbulator steels .078
1 .078 spacer plate with reverse wave (eliminates the belleville spring)
5 Borg-Warner forward clutches .070
5 Forward steels .090
2 Borg-Warner overrun clutches .078
9 Borg-Warner Hi-Energy 3-4 clutches .065
3 3-4 steels Kolene .060
5 3-4 Steels Kolene .076
2 3-4 pressure plates .128
5 Borg-Warner low/reverse clutches .087
5 Low/reverse "low drag" Turbulator steels .068
1 3-4 apply ring 5-tabs
1 .062" 3-4 snap ring
"Other"
Sealed Power Beast sunshell
OEM 29 element input sprag (late design)
Borg-Warner low/reverse roller assembly (late design)
Vamac 3 lip rear seal (prelubed)
Transtech paper & rubber (gasket) kit
Transmission filter (OEM)
Converter solenoid filter
Bushings (latest updates, including Teflon front pump & extension)
Thrust washer kit
Sealing ring kit
HD Bearing kit (Timken)
Borg-Warner Hi-Energy 2-4 band
Trans-Go Performance Shift kit w/accumulation for nice part throttle shifts
Trans-Go vacuum modulator
$635.01 is the price for this kit.
"Front pump"
Seal retainer
Late design seal
"Other"
Thrust washer kit
Sealing ring kit
LS1TECH Sponsor
tranny
Just so everyone knows im not bad mouthing Probuilt. The products were as stated. Im putting this through a mid 600rear wheel horsepower car (mustang dyno). I ll give ya a call though Dana just to see if you have any suggestions. Could have been my trans builders fault I have no clue.
Originally Posted by Pro Built Automatics
If you are having problems with this, call me at 909 7951876 anytime past 10am PST and I will be glad to help.
