Clutch switch.
i assume you still can start your car, so it will be the switch at the top of pedal. i bet your cruse control ain't work either.
take the kick panel off and that black thingy off. now you can see on top of pedal, there is a switch with push bottom. it good possible if you just had new master cyl or did drill mod. when you put it back, must knock the switch out. all you have to do is take the clip hold the switch out and turn that little clip so the push bottom side will stick out more. now you need to make sure when the pedal is release, it will push the bottom all the way in.
if the switch is in it good, probably need the new switch
K cool.. So it is the same switch. I shoulda posted that I was wondering that. On the coe check list it showed like it was 2 different switches. Come to think of it I think they are 2 different ones. Cause I know my cruise control switch is not hooked up but I still need to push the clutch all the way in to start the car.
