purge kit hard line
Old 09-27-2005, 02:05 PM
89ws6formula50's Avatar
Default purge kit hard line
I got my NOS purge, (install instructions from Matt@HSW)
I see many people making it vent by the windshield etc......how the heck do you do that with this lil hard line that came with the kit?
Old 09-27-2005, 02:24 PM
David@TNT's Avatar
Im assuming that you were supplied with a 6in line then.. You will need about 3ft to make it out the hood correctly.. You can buy some 3/16 ss tubing typically used for brake lines, you need to flare 1 end and just put a #3b-nut/sleeve on it to acheive the same goal.. Thanks David@TNT
Old 09-27-2005, 02:43 PM
LETZ RUN's Avatar
i used this poly flexable tubing from cold fusion.. that stuff is super simple.
Old 09-27-2005, 03:39 PM
gollum's Avatar
Use 3/16" hard brake line. It is cheap, bends easy, comes in different lengths from 1 foot to 5 feet, and is availible from any auto parts store.
Old 09-27-2005, 05:27 PM
Matt@HSW's Avatar
Either way will work. We do have the poly flexable tubing from cold fusion.
Matt
Old 09-27-2005, 05:28 PM
NitrousDirect's Avatar
This post is to take up meaningless space also
Old 09-27-2005, 06:34 PM
well then so is this
Old 09-27-2005, 06:38 PM
Rofl
Quick Reply: purge kit hard line
