Textralia Question
Old 09-27-2005, 03:40 PM
Bluehawk27's Avatar
Default Textralia Question
Real stupid question here, but wanted to double check. Which side of the clutch disk points to the engine on install? THanks.
Old 09-27-2005, 04:48 PM
kidkl's Avatar
The side with the large hub point towards the pressure plate.
Old 09-27-2005, 08:47 PM
SPEEDYws6's Avatar
Hey it's better to ask than get it wrong... Like said above, the part with the hub sticking out goes toward the pressure plate (away from the engine). When you put the disk up to the flywheel the pads should contact the flywheel, if it doesn't it's backwards.
