any ideas why on decel my car goes pig rich?
DFCO sure doesn't seem to work for me.
I can't figure out why if I decel in gear the car goes super rich instead of leaning out as it should.
Could this be related to my evap system? This is one thing I have noticed never passes the readiness tests.
I have been trying to solve this mystery for over a year now. Looking for ideas.
LS1 Tech Administrator
You can disable DFCO or you can try working at it by trimming your VE table in the cells that achieve high vacuum (15-30 KPa). Most of the time the number is too high and a rich condition occurs.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
wouldnt disabling dfco make it worse?
I thought dfco was supposed to cut fuel during decel or off throttle situations?
I was thinking for some reason dfco wasn't working properly on the car, thus this condition???
I am seeing this via my wideband.
Both. Any time I let my foot off the gas in gear it goes rich, it also does it if I throw the car into neutral while rolling. In netrual, at least, after about 10 seconds it will pretty much recover back to 14.7, while deceling in gear though, never. It will go as rich as 10:1 and sit there until I get on the gas again.
It's annoying for 2 reasons. 1. It has to be wasting gas, which does bother me, I do want maximum mileage for my combo. 2. it throws the ltrims so freeking positive that when you get back on the gas it spikes super lean 17:1 at times before settling back in. That lean spike scares me being a FI car. I want to be able to decel and then stomp on it if I want to without worry.
some releveant details.
stock fuel lines, CAS referenced FP regulator, Ractronix pnp fuel pump. Mototron 60# injectors (did it with my Lucas 42's as well) LS6 intake with EGR. 212/218 .522/529 114 cam.
it did it with my blower, does it na, does it with my STS.
You DFCO is not cutting in properly because of your modifications. You will need to increase your entry and exit MAP, and you may want to take a look at your entry and exit RPMs. The best way to do this is log your MAP kpa while driving and during decel. Adding about 10-15kpa to each may do the trick. I forget what I added to mine, but it worked perfect.
I probably have the same issue. I've had to dial back my VE's at low MAP by as much as 40%. If I coast for bit and then get on it, my STRIM goes way positive.
So I'm looking at the DFCO tables in LS1Edit. In Edit there is a table of MAP v. MPH and 65 KPA is the lowest setting. The KPA is fixed. You can change the enable & disable rpm, and the delay.
it's not VE, scaled it so far back the values are in the teens. no difference, except the car just runs like crap at those loads
is there anything I can scan to verify when dfco is kicking on and off?
i tried a blind stab at adding 10 to the entry exit values as suggested, no dice. I also didn't understand why I would add to the number? seemed like I would want to reduce it???
