Billet Aluminum N2O Bottle Holder Rattles (Anyone have this holder?) Pics
Old 09-27-2005, 04:23 PM
2001 Red Coupe Bandit's Avatar
Default Billet Aluminum N2O Bottle Holder Rattles (Anyone have this holder?) Pics
I have this holder at an angle in my trunk area. The car isn't done yet, but the guy that was installing said it is rattling.
It is rattling side to side (Left to Right) where the handle goes into the base unit that is bolted to the trunk area.
ANy of you have this and know of a fix? I could wedgle something in there to stop it, but just wondering if you have this same holder?
Thsi si not my Car BTW.
Old 09-27-2005, 04:26 PM
JustAnIlluzion's Avatar
u could add some felt to some of the area
Old 09-27-2005, 04:40 PM
99SLOWC5's Avatar
felt or some electrical tape on the inside, simple fix
JEFF
Old 09-27-2005, 04:55 PM
Elite_Hot_Rod's Avatar
You can use some velcro on the radiouses and it won't scratch the bottle.
Old 09-27-2005, 05:13 PM
LeMansBlue04's Avatar
Hi Gary,
I was in the shop yesterday when they were putting this in. P&J spotted the potential for noise right away. Can you say shim???
I hope the new system works out great for ya. What did you do to increase your fuel supply?
Old 09-27-2005, 05:19 PM
Thanks sGuys for all the quick replies
No additional fuel pump should be needed on a 100 shot wet.
Here is a reply from the Maker of this unit:
Hey Gary, Try something. We double ream the holes which means we put the handle in the base and ream the holes in both pieces at the same time and then we turn the handle over and ream through both pieces again. The reason for this is so when the assembler puts it together we don't know what way the will put the handle in since it is symmetrical. We ream the hole to he pins because the diameter always changes on the pins from our supplier.
Turn the handle around in the base and in should be tighter. You can just leave the handle and rings on the bottle and turn it all around to do the test. If this works, take the 4 bolts out that holds the handle to the rings and flip the handle.
It is not in front of me so I can't test it right now , hope it works
Old 09-27-2005, 05:53 PM
96silverram's Avatar
Looks good !
Where's your blow down tube ?
Old 09-27-2005, 07:30 PM
Robert56's Avatar
That's sweet looking. If I wasn't such a tight wad, I would use that mount also, but have a blanket know so wouldn't see it anyway. I sure like the "Nitrous Under Glass" look (for those that are old enough to remember "Hemi Under Glass").
Robert
Old 09-27-2005, 10:17 PM
JoeyGC5's Avatar
Robert
I'm thinking more of dual hemis in a power wagon converted truck
Old 09-28-2005, 09:41 AM
Nitro Dave's Nitrous Outlet's Avatar
Thats what I like to see.There is finally a bottle in Garys Ride......
Dave
Old 09-28-2005, 11:03 AM
There is a bottle, but that ISN"T My Car in the picture, that was just for illistrative purposes.
I will post pics when mine is done :
