G5X2, 5.3 ported heads, and flycutting pistons???
ok, i have a 2002 T/A with a G5X2 cam, and bought a set of 5.3 heads and am getting them ported and putting 2.02/1.57 valves in them. they are not being milled, just cleaned up, probably 2 thousands or so. my question is, is anyone running this setup on stock pistons, or do i stand a good chance of having to flycut the pistons? i know i can probably just go with a thicker head gasket, but don't wanna lose compression or quench from what i understand. any help, ideas, or advice would be greatly appreciated.
TIA
David
TIA
David
i looked, and did a search and found a bunch of things, but no one ever answered if they actually were able to run the heads and cam on uncut pistons, so i was trying to see if anyone may have done it since it was last asked and would answer, cause if i can do it, i will deifinitely post and tell it worked or didn't, so people like me wont have to make continuous posts. sorry if i am re asking, i am just trying to see if anyone has run this combo with these size valves.
I think reguardless of what people here tell you, you should have it checked to make sure it isn't closer then you want. I had my pistons cut, but I had my heads milled a good bit.
