Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
What are some good quality gloves?
Old 09-28-2005, 11:35 PM
Moderator
BizZzatch350's Avatar
Default What are some good quality gloves?
I need some because I alway seem to cut my fingers up, today I sliced my index finger good installing a upper radiator cover, BMR makes a weapon, I tell you.
Old 09-28-2005, 11:36 PM
DONAIMIAN's Avatar
i like the mechanix
Old 09-28-2005, 11:44 PM
Moderator
Originally Posted by stang killer
i like the mechanix
How do you like the quality and movement? I'll drop some chedar on some good gloves
Old 09-28-2005, 11:47 PM
BigSteele's Avatar
cmon real men dont wear gloves! just build up the calluses! (sp)
just joking
i took a picture of my hands after i installed cam and springs, you should see it
Old 09-28-2005, 11:50 PM
Moderator
just joking
Negatory, I also have hand problems so it make it kinda easy to cut myself.
Old 09-29-2005, 12:13 AM
LS7 Member
UTzo6's Avatar
Driving gloves? Working gloves? details...
Old 09-29-2005, 12:30 AM
Moderator
working on car gloves
Old 09-29-2005, 07:20 AM
mitchntx's Avatar
I've used Ringers, Mechanix and Iron Horse gloves. They each have their own upside. And it will depend a lot on your hand as each has their own fitment "quirks". Mechanix brand tends to have regular length, fat fingers, while ringers have a slightly longer, skinnier finger. the Iron Horse brand has a very tight fit around the hand, which makes it difficult to get off when sweaty.
Mechanix brand has a warranty. If the glove WEARS out, they will replace them at no charge. If you cut them, rip them, burn them ... no dice. But if you wear a hole in the thumb or finger, they will replace them.
Several years ago, I bought 3 pair of Mechanix brand gloves. I have a dirty pair, and a clean pair that I use when working on the race car. And the 3rd pair is hanging on the shelf. When the dirty pair finally wears a hole, the clean pair rotates to the dirty pair, the new pair become the clean pair and I send the worn pair back for replacment. When the new ones come in, they go on the shelf.
This warranty does not apply to their "Fast-Fit" line ...
Old 09-29-2005, 09:33 PM
BigSteele's Avatar
sounds like you konw your gloves! good useful info
heres the pics of my hand after the cam/springs install. the back springs are what did most of it
the only worse time I got cut up was my clutch swap, I had little cuts all over, then when I bled the MC I got brake fluid all over my hands. That did not feel too good and im sure it wasnt healthy
Old 09-30-2005, 09:08 PM
paper doll's Avatar
good lord no gloves at all? ehh thats not that bad haha, i get my hand cut open when i think about touching the '74, but i only wear gloves when toxic fluid is involved
Quick Reply: What are some good quality gloves?
