aussie vs. ls7 vs. ls6
ls6 clutch kit then the master and slave comes to about 650 or so
ls7 clutch kit ls2 fly wheel and master and slave abounr 850 or so
aussie clutch kit 1000
i want a clutch thats gonna last a long time, good street mannors, and will take a beating, and dosent make a noise.
but 1 queston, does that ausie clutch kit come with every thing?
cluch disk, p/p plate, pilot bearing, throw out bearing, master and slave?
and what master and slave should i use if i go w/ the ls7 clutch
http://www.textralia.com/
call jeff at 9728141800
he is in texas, or go to the web site for the 800 number. you will be talk to peter and he is 7 hours behind central time
Originally Posted by bad6as
link to a place that sells the kit
The Textralia OZ700 now comes with a choice of 3 flywheels;
A. OEM (OZ700oem)
B. 18lb Steel Billet (OZ700sb)
C. 8.8lb Aluminum Billet OZ700ab)
Kit contains;
1. Pilot Bearing
2. Flywheel
3. ARP Flywheel Bolts
4. Clutch Plate
5. Pressure Plate
6. Pressure Plate Bolts
7. Thrust Race/ Throw Out Bearing
8. Slave Cylinder
9. Install Alignment Tool
10. All Digitally Balanced & Ready to Install
Current forum sponsors who are distributors of these products;
(alphabetically)
A&A Corvette
Byun Speed
Fastech
LG Motorsports
Scoggin Dickey Part Center (SPDC)
A. OEM (OZ700oem)
Kit contains;
1. Pilot Bearing
2. Flywheel
4. Clutch Plate
5. Pressure Plate
8. Slave Cylinder
(alphabetically)
A&A Corvette
Byun Speed
Fastech
LG Motorsports
so for my being 19 what clutch should i got with
ls6
ls7
aussie?
i dont have any super serious mods planed and if i do go boost or n02 then ide sway the clutch out again is needed to. this is a dd that gets driven hard
ls6
ls7
aussie?
