Northwest Members WA, OR, ID, MT, WY, SD, ND
What would casue 1st to pop out into neutral?
Old 09-30-2005, 11:13 PM
00Vette's Avatar
Default What would casue 1st to pop out into neutral?
Every once in a while 1st will pop out into neutral. While at a light or stop sign, I'll be waiting in first to go and then the light turns green. So I let off the clutch and pop out comes first into neutral. When It does that I have to put it in and out of first till it goes forward. I have been just putting it in second so I don't hold up traffic. I have never heard of that happening and have no idea what would cause it. It only happens to first gear and only some times, but now I freak out every time I'm at a stop and in first waiting to go................The car drives great other wise.
That's exactly what happened right before I broke my rear end at Bremerton a while back. I was in first and staged, when the lights came down I let off the clutch and first poped out into neutral. My oponent was already 1/4 the way down the track as I crammed it into first and let off the clutch for a second time..........And POP the rear end broke.
Has anyone ever heard of this happening?????
Old 09-30-2005, 11:20 PM
Crisisman's Avatar
This has happened to me on 3 occasions. Each time it felt like I had just not quite put it all the way into gear, so the system just kicked it clear. I just put it back in, making sure it goes completely and have no further issue. This hasn't happened at the track, but I'm usually **** about making sure it's fully engaged when I'm getting ready to launch.
Old 09-30-2005, 11:39 PM
00Vette's Avatar
Yeah.........That's kinda what it feels like to me as well. But it has happened about 15 times in 2 days of driving. I have been driving my car alot cause I'm trying to break in my rear end. Did your car make a pop sound as it spit out of first?
And do you think that a bent shift fork would only affect first gear?
Old 09-30-2005, 11:43 PM
Crisisman's Avatar
The sound it makes I would describe as a "click" more than a "pop". As for your second question, I haven't a clue, no tranny experience here. Perhaps Ellis can pipe in on that one.
Old 09-30-2005, 11:47 PM
Racehead's Avatar
Well if you didn't have it all the way in = no problem. If you DID have it all the way in = problem. They shouldn't pop into neutral under any circumstance if they were fully engaged to begin with.
Old 09-30-2005, 11:50 PM
00Vette's Avatar
If it was fully engaged and poped out but only some times what would you say could/would cause that?
It feels (sometimes) like it don't smoothly want to go into first, other times it does and still pops out.
Old 09-30-2005, 11:58 PM
Racehead's Avatar
I'm going to have to refer you to Ellis. I work on Allison's, Spicers, Rockwells, Meritor autoshifts etc. on Semi's, not T56's. If I were to guess then I'd say you have some sort of shift rail/fork problem. I'm sure Ellis will chime in at some point.
Old 10-01-2005, 10:19 AM
WAHUSKER's Avatar
I had an old Borg Warner T10 that did this & it was poorly adjusted shift linkage. (I ended up grenading the tranny) Not to say it isn't a bent shift fork inside, which would yield the same result. Time to let Ellis have a look at it.....
Quick Reply: What would casue 1st to pop out into neutral?
