Do You Need A New Flywheel With A New Clutch??
Old 10-01-2005, 11:26 AM
nikeair042's Avatar
Default Do You Need A New Flywheel With A New Clutch??
I am about to buy a clutch, but I am not sure if I need to spend the money on a flywheel also. I found a LUK online for $450 with all clutch things and a flywheel. But on Ebay there is a SPEC stage 1 for $290, just the clutch and everything that goes with it. Do I need to buy a flywheel with a new clutch system? And do I have to buy a new master slave cylinder? Any help is appreciated, thanks!
Old 10-01-2005, 11:28 AM
01ls1's Avatar
You can have yours machined...
Old 10-01-2005, 12:21 PM
10 Second Moderator
Torkman15's Avatar
Yes you can have it machined but you will spend as much money in machining and balancing as you would getting a new GM piece.
If you get it turned dont forget to have it balanced. You will shake like a dog $hitting razer blades if you dont. Good luck, Tom
Old 10-01-2005, 05:02 PM
keliente's Avatar
That is not true. Most machine shops will take care of your flywheel for $40-$50.
You do not need to replace your flywheel when you use a new clutch. You have a '99 car, it would not hurt to buy a new master and slave cylinder (replacing one without the other is futile unless one of them has gone bad for sure). I have an '00 car and after a while I could no longer shift into 2nd gear at wide open throttle because of failing hydraulics...needless to say when I went for the stage 2 I bought a new master & slave.
Old 10-01-2005, 05:27 PM
badazz81z28's Avatar
Where do you get your machine work done? I have never paid more than $32 to have one resurfaced. Balanced? Not required nor necesssary..
Old 10-01-2005, 08:56 PM
10 Second Moderator
Torkman15's Avatar
Should not matter where I get my machine work done. I'm speaking from experience after I had a flywheel turned and my motor had a bad vibration after turning without balancing. Do a search on this I'm sure I'm not the only one who had this problem.
I bought the flywheel (new GM piece) from SLP for $50.00 but it was a sale price so you might not get your new one for less than what you can turn yours for.
Do a search, get more info on these clutches and hydraulics and you wont be sorry. Good luck, Tom
