Should I get a bigger stall?
Old 10-02-2005, 02:11 PM
Import Patrol
CrawlinWS6's Avatar
Default Should I get a bigger stall?
I am currently running a TCI ssf 3500 stall, also have a 150 shot and a 230x224 cam. Was thinking about getting the converter restalled to 4000, what do you think
Old 10-03-2005, 06:09 AM
Nocturnal SS's Avatar
That might be too high.
Old 10-03-2005, 04:55 PM
rufretic's Avatar
If you don't mind spending a little extra money, I bet the Super Stock 4000 Extreme converter would give you a nice gain. Its also made stronger for nitrous. I have the regular SS4000 and it blew my other converter away. Better trap and ET and it also drives better on the street(not as loose). It might net you your goal. You saw it got me to where I wanted to be. My best before saturday was 12.2 @ 109.
Old 10-03-2005, 05:08 PM
FelixIlka's Avatar
I'm going with a 4k right off the bat when I jump into a T-Rex cam, so I say go for it and get a bigger cam!
Old 10-03-2005, 05:09 PM
FelixIlka's Avatar
BTW, what's your new best rufretic?
Old 10-03-2005, 05:20 PM
rufretic's Avatar
11.94 @ 113.48 with a 1.68 60' It hit so hard I couldn't get it to hook up. I had to use the traction control to pull 1.6s. If I had slicks, theres a lot more in my setup. I should add that I also switched from 3.23s to 3.73s. I only have BFG drag radials but I do have a lot of susspension work done. With my old setup I was able to flash it off the line and dead hook but the best 60' I could pull was in the 1.7s.
Old 10-03-2005, 05:25 PM
Import Patrol
CrawlinWS6's Avatar
ya, but I am trading my tci ssf3500 for a fellow members tci ssf4000. I called tci and they told me I should be fine
Old 10-03-2005, 05:29 PM
rufretic's Avatar
Where does your cam peak?
Old 10-03-2005, 05:36 PM
Import Patrol
CrawlinWS6's Avatar
this is the info on my cam. Thunder Racing Custom "Reverse Split" Camshaft - 230/224 .575/.563 111 LSA 2200-6800 RPM Power Band. Excellent mid-range & high RPM power. Automatic cars require computer tuning and it is recommend for optimum results on manual transmission cars .
Old 10-03-2005, 05:49 PM
rufretic's Avatar
Did you ever have it dynoed to see where it peaks? Because if your making power to 6800 then you could definitly use a higher stall.
Old 10-03-2005, 05:52 PM
Import Patrol
CrawlinWS6's Avatar
ya, that what it showed on the dyno. Just wondering, what brand stall did you have originally that you changed it out to
Old 10-03-2005, 05:56 PM
rufretic's Avatar
I don't want to bash so I'll pm you.
Old 10-03-2005, 05:58 PM
Import Patrol
CrawlinWS6's Avatar
that will work
Old 10-03-2005, 06:43 PM
gator's 99TA's Avatar
have you considered a fuddle? go to the drag racing results forum and you will see what i did with one. it was a fuddle 3600 9.5" convertor. flashed perfect for my 125 shot. went 1.4 60' on the radials.
Old 10-03-2005, 08:00 PM
Import Patrol
CrawlinWS6's Avatar
Well seeing that this is an even swap, and I am doing all the work myself it not going to cost me nothing other than a few quarts of fluid. So I am going just do the even swap.
Old 10-03-2005, 08:02 PM
rufretic's Avatar
Not a bad deal.
Old 10-03-2005, 08:09 PM
Import Patrol
CrawlinWS6's Avatar
Ya, I plan on doing this on saturday, but I got to find a someone's driveway to do it on. Damn apartment life sucks
Old 10-03-2005, 08:11 PM
that 4K stall will push to about 4900-5000 when you hit it with a 150 shot. thats not a good thing.
Old 10-03-2005, 08:38 PM
Import Patrol
CrawlinWS6's Avatar
I was concerned about blowing thru th converter. That why I talked to the techs at tci, and they told me I'll be fine, but not to up the shot.
