Critique my nitrous progress....
Here's a couple of things...
1) The rails are going to be stripped and we're going to weld aluminum tabs to allow it to bolt to the intake
2) After the rails are welded, we're going to powdercoat them either mirror or gloss black
3) The fuel end needs to be cut down
4) The fuel solenoid is going(reference in pic 1) direct below the Fast logo with a straight pipe coming out and 90 back to the rear of the car into a 45 and than into the rails.
Direct Port 1
Direct Port 2
Direct Port 1
Direct Port 2
I am sure the wife isn't happy with the nitrous setup on the kitchen table!
Looks good, I have a bender from either SnapOn or Mac that does pretty nice bends with 1/4", how tight of a radius are you trying to get? I have filled tubes with sand before and capped both ends, then bent it around a rachet handle
Originally Posted by Phil99vette
I want to tighten up the rear bends, they fit but way too big. I purchased a bender from autozone but its like a 1" radius or so, I need like 1/2".
Phil
Phil
Robert
Short update...
I finally got some time to start working on the nozzle to rail connections. We had thought that they were going to be a PITA but after we made a little template for bending angles and where to start to get the desired finish angle makes it super easy.
Phil
Phil
