LS6 intake?
Originally Posted by 98V6camaro
No you do not need any special hardware.
You will need the coolant pipe and coolant plugs
https://ls1tech.com/forums/generation-iii-external-engine/386287-people-looking-coolant-pipe-coolant-plugs-ls6-intake-swap.html
Originally Posted by camarodave98
Will any ls6 intake bolt onto my 98 z28? From any car, any year? Will i need any special hardware?
Thanks,
David
Thanks,
David
will one from a corvette fit?
and in answer to the question on how much they run, iv been doing alot of shopping and the seem to be running anywhere from 300 to 350 used. The one i may be getting is 320 shipped.
LS6 intake?
I am recently new to the LS1 side, use to be a LT1 owner recently converted.
I am trying to get some information about the LS6 intake. Is the LS6 and the LS2 intake the same thing? What will work on my 99 SS LS1?
I am going to be porting my stock TB as well.
SSU's Drunk Typing Whore
First serch...lots of good info about this out there.
Long story short dont go with the LS2, go with the LS6 manifold.
There is also a write up on the swap on www.LS1HowTo.com
Good luck
Good luck
