stupid question how does a stall work and
A stall is like a clutch for automatics. Look here for more info http://www.fuddleracing.com/wst_page3.html You cant turn off a stall.
Originally Posted by ImportPatrolWS6
damn now thats a loss. I have not heard of loses that large
My input on how:
Take 2 fans and face them toward each other and turn one on. The one that is not on will start to spin after the other one is up and runnin because of the air pressure that is generated. From here look at the fan that is turned on being driven by your engine instead of electricity and the other fan hooked up to the input shaft of the tranny and instead of air pressure there is hydrolic pressure. The larger the fans the faster the unpowered fan spins up and the smaller the fan the slower.... so far so good. Converters are load sensitive meaning the more load that is applied to one side will require more load on the other to keep from moving. Say your going down the road in your car and you come to a hill, the car starts to slow down because more load is being applied to the tranny side of the converter but not the engine side so you give it more gas to equalize the load to maintain speed. In general the smaller the converter, the higher stall speed it will have because of the smaller fans desciption I was talking about earlier. Say you have a V8 S10 and have a 355/TH350 with a 3k converter in it and can footbrake 3kout of it. Take the drivetrain out of the S10 and put it into a 1 ton dually- you will probably be able to footbrake it to 4k now because of the extra load the converter sees compared to the S10. Same goes with engine power, you have a 400hp engine in the S10 and can footbrake to 3k but swap engines to a 550hp engine and probably footbrake to 4k. Another thing is gears, the lower the rear gears the tighter a given converter will be because of load- the lower the gear, the lower the load will be to move the vehicle because of torque multiplication the gears will give. You have a car with 2.73s in it and can footbrake 1800 but swap to 4.10s and probably can only get 1500 out of it.
