Nitrous Oxide - can my stock car take a 125 shot?
View Full Version : can my stock car take a 125 shot?
Lennyd
10-04-2005, 03:11 PM
can my stock 00 camaro z28 handle a 125 wet shot?
BIRDONNOS
10-04-2005, 03:47 PM
i think you would be fine with that shot i sprayed open 5177 solenoids which is about 140 to the rear wheels on my stock motor it ws a dry shot. just watch your timing and airfuel if possible pull about 4-5 degrees of timing just to be safe.
Matt@HSW
10-04-2005, 03:57 PM
Your stock bottom end can. But when/if you put the cam in and do a tune I'd look at pulling some timing if you add any and take a look at your fuel system. It wouldn't hurt to upgrade it at that point.
Matt
NitrousDirect
10-04-2005, 04:28 PM
Yes you'll be fine. But there are always general things that are good to do as precautions like pull 1.5-3 degrees per 50 HP, a set of colder plugs, and if you want to run 150 or more HP then upgrade the fuel pump, might want to consider a fuel pressure safety switch also
TRMIN8R
10-04-2005, 04:32 PM
Do it!!!
NitrousDirect
10-04-2005, 04:43 PM
We'd be happy to help you with anything you may need, give us a pm, email or call!
Nitro Dave's Nitrous Outlet
10-05-2005, 12:34 AM
All day long......Go for it.If you would like and tech advice please fell free to send me a pm.
Dave
