what cam to run with 150 shot
Originally Posted by 1fastz28nx
is that the magic stick cam?
no.
There are a million cams out there man. You want something that has a tad bit wider lsa and something with a little larger exhaust side. the 231/237 is definately a nice cam though. But just search on here, you will find out about another million choices.
so do you think the magic stick would be a good choice though? I plan on getting a set of stage 3 ls6 heads soon. what i really want to do is get a 408 with the texas giant cam but that's gonna happen just yet.
well you said your car was bone stock and with the stock CR and everything else being stock any higher duration cam would make your car lose low end power and torque, and since your tuning and valves are stock its senseless to run any higher rpms. with this cam you might even get away without a custom tune. if you were not using nitroud i would even say you should go with 212-216-114, but with a 150shot of nitrous i strongly recommend a timing tuner where you can pull back spark advance. about 7deg of retard should be safe.
hope this helps
hope this helps
Any cam.
Use the one that has the street manners you want off the bottle. I don't recall ever reading someone saying their cam didn't work with nitrous. You will see +150 with a 150 shot with any cam.
I have used 232/236 112
232/236 111
224/230 114
stock
01 Z06
232/236 111
224/230 114
stock
01 Z06
this might be a dumb question but why 214-222 and not a longer duration
Originally Posted by Spinmonster
Any cam.
232/236 111
224/230 114
stock
01 Z06
232/236 111
224/230 114
stock
01 Z06
Here is some samples, pick one:
218/224 duration, .563"/.568", 114lsa
220/224 duration, .564"/.568", 114lsa
220/226 duration, .564"/.570", 114lsa
222/226 duration, .566"/.570", 114lsa
224/228 duration, .568"/.571", 114lsa
224/228 duration, .581"/.588", 114lsa
224/230 duration, .581"/.592", 114lsa+1
224/230 duration, .568"/.573", 114lsa
226/230 duration, .570"/.573", 114lsa
226/230 duration, .570"/.592", 114lsa
228/232 duration, .588"/.575", 114lsa+1
228/232 duration, .571"/.575", 114lsa
230/234 duration, .592"/.598", 114lsa
230/236 duration, .592"/.602", 114lsa
230/236 duration, .592"/.602", 115lsa
232/236 duration, .595"/.602", 114lsa
232/238 duration, .595"/.605", 114lsa
232/238 duration, .595"/.605", 115lsa
234/238 duration, .598"/.605", 114lsa
234/240 duration, .598"/.609", 114lsa
