What PID in HPtuners do we use to line out IAP?
I have the VE table pretty much there and the STIT/LTIT/ RAF tables lined out as well as the Effective area (I think). I have followed several threads and searched for the proper way to line out the "Idle Air in Park", but I'm not sure as to the PID (In HPTuners) that I need to monitor as I adjust the "Idle air in park".
There was a post that referenced EFILive which used DESIAC, but I assumed that was "Desired Idle air" in Hptuners. I have reduced my IAP quite a bit and it does drop, but I don't feel it's the proper PID to make sure it's right.
TIA
TIA
check here....
www.audiohelix.com/file
HPT 2.0 histograms with PID explinations in the small print below the histogrm
you're welcome
and you can treat the results as a copy/paste just like LTFT/STFT
you're welcome
