Speed Density tunes
Speed Density tunes
Anyone ever run into this one? Did a speed density tune last night (over the top of someone else's tune). Started with LS1Edit, got frustrated, and switched over to EFILive. Followed the normal procedure to a T. The problem is, if you physically unplug the MAF the car will only idle -- if you touch the throttle, it cuts all spark. As in turn-off-the-key no spark. Plug the MAF in, car runs fine.
PCM is a 2001 F-car in a race car.
Hey Brains, do you have a MAF I can borrow for a few minutes one day? I need to see if mine got hosed. I know I need injectors, but the damn thing has + LTFT's at idle that won't go away. I don't think my VE at idle should be 79%.
Where do you live again? I tried SD this morning on the way to go sign up for U of H. My LTFT's went from the normal +25% to -8.6% at idle. No wonder I could NEVER get it correct. POS! Now that I have the MAF and IAC unplugged, I'm doing better. I would still like a MAF for days where the weather is all over the place because my IAT's are erratic in Houston traffic. Now I know why i was hitting 103% VE at 1200 rpms. How much do you want for me to borrow it? My black *** might go to the pawn shop with it.
Go get you some electrical parts cleaner and get that bish cleaned up...It will probably fix your problem
I've done that twice already. I think it got fucked way back when oil shot up on it through the intake. Yeah, I've had some issues...... I'm just going to do SD for now but need a MAF to confirm everything when I get done. On average, I drive like a grandpa and don't go over 7% on the TPS, so I just need to get my low MAPS in order. Does anyone know of a good 85mm OD pipe that is precut and smooth that I can replace my MAF with? I have the stocker but figured I mine as well get a larger diameter tube. With the screen on there and not being used, it's just holding back airflow.
You can't remember where I live? I guess that's why I still have my TV set. You know you can't trust a black man with anything. Probably pawn it, and go buy some crack and then rob the liquor store -- and it all starts with the loan of a mass air meter.
I'll PM ya my info, I'll be home around 6:00'ish if you want to stop by tonight
Please have all your car key sets available at the front door. Also if you could label them for my convenience, I would really appreciate it. You're like my crack dealer anyway. You have any part I need readily available. If I go down, I'm taking you with me. If you have an O2 sensor I could buy off you, that'd be great. I bought a brand new Bosch sensor about 2 months ago. If it were a person, it'd be black because it's lazy as hell. The original one doesn't oscillate that great, but it works better than the new one. I knew I should have never gave my back O2's away. Oh well, at least someone got some use out of them for a couple years.
