Target Idle Speed M6 vs A4
Old 10-06-2005, 10:49 PM
soundengineer's Avatar
Default Target Idle Speed M6 vs A4
so why can A4's idle so much lower than an M6??
what is so different that an M6 has to be 150-200 rpm higher??
Attached Thumbnails Target Idle Speed M6 vs A4-a4idle.png   Target Idle Speed M6 vs A4-m6idle.png
Old 10-06-2005, 11:53 PM
luv2spd's Avatar
I don't think it *has* to be higher...but it prob. makes it easier to start out from a stop to have it a little bit higher.
Old 10-07-2005, 08:18 AM
Ragtop 99's Avatar
The converter is a fluid coupling and has much more mass than just having a flywheel. Also the A4 idles are not as smooth as the m6, but the converter helps filter it a bit.
Old 10-07-2005, 12:43 PM
silverTA2002's Avatar
Is there any benefit to having a lower rpm idle? Fuel economy?
With my heads/cam, I bumped my idle to 850, but if I don't need it that high, should I tune it to idle lower?
I figure the higher idle makes it idle smoother, and easier to put into gear. But, hurts fuel economy?
Old 10-07-2005, 05:57 PM
YankeeVert.'s Avatar
You bet it hurts fuel economy. If you do a lot of stop/go driving then it REALY hurts it.Remember if you are stoped at a light you get 0 mpg. The higher the Idle speed the more fuel you are burning. The A/F ratio is the same (controled by the computer) so if you put more air in (higher idle speed) you must add more fuel.
Old 10-07-2005, 06:02 PM
Interesting..... And I do a ton of stop and go driving.
Maybe I should tune to lower my idle. And as long as it isn't too rough, and I don't stall..... leave it there. I don't have a very large cam.
Old 10-07-2005, 06:13 PM
vtanju's Avatar
i think the idle on the A4 is lower at operating temperature to allow for softer gear engagement from neutral and to allow easier control of the IAC. if the idle was set at 800rpm on an A4 in gear you will have to press on the brake a little harder to keep it at a standstill and thats a bit inconvenient. my opinion is that it has nothing to do with the torque converter and its filtering abilities. another reason maybe is that its alot easier to launch an M6 from 800rpm than at 650rpms.
Old 10-07-2005, 06:25 PM
P Mack's Avatar
The higher the idle is on an automatic, the harder it pulls when you're in gear with your foot off the brake. You don't want to be constantly riding the brakes when you're trying to creep along in a parking lot, etc. And yes, I know this doesn't apply to a car with a stall converter.
Old 10-07-2005, 06:28 PM
Sharpe's Avatar
My stock 99 LS1 M6 idles at 800 RPM.
Old 10-07-2005, 06:43 PM
IF you look at th epictures the idle is at 800RPM when the car is up to full operating temperatire....
teh A4 is at 650
Old 10-07-2005, 06:47 PM
Sharpe's Avatar
Oh. I looked at the pictures and it looked like one was idling at 1000 and the other at 850.
I can't believe the A4 idles that low.
Old 10-07-2005, 08:44 PM
SmokingWS6's Avatar
I figure its harder to kill than if you had 500 or 550rpm at idle for an m6.
Old 10-07-2005, 09:00 PM
WS6FirebirdTA00's Avatar
i dont buy the "higher rpm uses more gas". try to set the rpm lower, itll bog adn with a big overlap cam you will see shittier gas mileage. theory and reality are totally different. if you set the idle on the a4 with the stock converter to a higher rpm itll be a pain in the *** to drive. i guess tahts why its lower. like stated, if you let off the gas with higher idle you dont want to be moving 10 mph lol
Old 10-08-2005, 01:33 AM
slow's Avatar
when idling a car gets 0 mpg.
You can't run as high of a idle speed with an auto, or you will have stall creep with the vehicle in gear.
Ryan
Quick Reply: Target Idle Speed M6 vs A4
