Mafless dry shot
Mafless dry shot
Anyway to tune for a mafless dry shot using HPTuners and EIO? Maybe set the car to go ridiculously rich when the car starts spraying. It would be preatty cool to do a DP Dry set up.
You can use an aux fuel pump to spike pressure and temp trick injectors into thinking they are bigger. use a vacumn reg, kinda like a boost reg system. Lt1 dry shots did this.
Also, in HPt is IAT vs Fuel adder, a seperate fuel multiplier on top of PE multiplier. Log on the spray and you'll see what I'm talking about.
Robert
Robert
