very bad vibration
one other thing i push it all they way to 120 try to drive out of it and the car acted like it was going to go boom. like the trans didnt want to go any faster the rpms went all the way up to the red line.
Well if your like me you'll fix everything but what the problem is. I replaced almost everything possible but the transmission output shaft, and that is what ended up being the problem. It was bent just enough to cause a bad vibration.Let me know what you find out. Traver
How hard was it to replace?
I bought the shaft used for $30.00. The bad part about it was the trans had to come apart. Traver
I just went through the same thing as well. Make sure you check the bushing in the rear of the case where the output shaft exits. I found that with mine the bushing was wiped out and spun inside the case thereby ruining the case itself. If the bushing spun you will not be able to install a new one and will need to replace the case.
