What do i need to sprya 175 dry shot??
Old 10-08-2005, 08:32 AM
BTLFEDSS's Avatar
Default What do i need to spray 175 dry shot??
I have a 2000 SS with a small cam and stock fuel system and 100 shot as of right now.I was thinking of upgrading to 42lb injectors and maybe a inline pump and will also be running Vp race fuel streetblaze 103/93 for spray runs
Any input would be appricated
BTLFEDSS
Old 10-08-2005, 09:20 AM
ATVracr's Avatar
There are a few people doing that around here.
the 42's will be fine but I would reccomend a intank (walbro) instead of the inline. They are pretty simple to install if you get the racetronics plug and play.
good luck with it.
Old 10-08-2005, 03:28 PM
Matt@HSW's Avatar
Pick up a set of injectors (42lbs will be good) and do an in-tank fuel pump, like a Racetronix kit or a walbo (make sure you get a hotwire kit) and you should be pretty much good to go.
Matt
BTLFEDSS
Old 10-08-2005, 03:34 PM
xaon's Avatar
Matt
x2. That is the setup I was using to spray a 175 shot for a while. Worked good
Old 10-09-2005, 02:30 AM
Robert56's Avatar
I agree with what's said. In addition I would log for KR and/or check with tuner for added timing. Watch your a/f also on log runs. Mostly, have fun kicking butt and taking names. 200 here 42's, walbro, 22* timing and having a blast.
Robert
Old 10-09-2005, 10:14 AM
BTLFEDSS's Avatar
Thanx Guys
BTLFEDSS
Old 10-09-2005, 11:52 AM
hondo's Avatar
you dont have the *****
Old 10-10-2005, 07:39 AM
BTLFEDSS's Avatar
BTLFEDSS we can meet on 146 sometime
