my conversion from 95 to 02 front clip
http://www.cardomain.com/ride/2131767/1
thanks to all of you guys boyd, xxxtransam and every body else who help me
Originally Posted by transam69230
should have used the formula front clip considering it is a formula, but it looks alright
geo 95 bird, since you did this, hopefully you can answer a question for me (I've asked it elsewhere on here before with no response) - are the 4th Gen A fenders the same shape as the 4th Gen B fenders over the wheels?
For some reason the LT1s look more sleek and less bulky than the LS1s (in that area, over the top of the wheel, as if the LT1 body sits lower on it's suspension points and was cut appropriately - I'm not saying it is, just trying to describe the look)
\ its a v6 why pay for a v8 used when i could save the money and put a brand new ls6 turbo charged i did my conversion in less than 500.00 and a couple of grants for the engine and 6 speed tranny. I'll have a brand new car for less than 10 grand
Originally Posted by Silver02TA
actually it looks to be a V6... notice gauges and under the hood
Originally Posted by geo 95 bird
they're different one is longer than the other
See what I mean? It's hard to describe, but the fender itself looks taller on the LS1 (from the top of the opening to the top of the fender), this makes the car look like it's bulkier and sitting higher. It's about the only thing I don't like about the LS1 look.
i did the same thing... except I have an Lt1..It was a red formula but now is a ram air t/a. i've covered everything down to the smallest details like the windshield wiper arms. I also swapped the whole interior including carpet, dash doors, panels the works from graphite to ebony. I dont' know how you plan to turbo an LS6 for less than 10k but if you can more power too you.. the over all cost of the turbo is going to run you 4K+ the motor used is going to be 2k+ plus you have a mess of wiring... easiest would be to get the interior and engine harness out of an 00+ bird. also you will need a new kmember, rack and pinion. blah blah blah. I'm in the works of a building a 6.0 iron block. which will one day be turboed but i know it's not fisable today. Also FYI you will want a new rear bumper to go with the side skirts... otherwise it just dosn't look right.
on a side note nice to see someone else driving a multi colored car for awhile.. LOL i drove mine for a month or so before i got in a booth.
as for the fenders... the are completely different. there is no way to alter a 93-97 fender to fit correctly.
speaking of fenders.. did you get the new brackets to go with the fender/bumper?
anyhoo nice job... if you have any questions about anything send me a PM...
Originally Posted by CONVERTED
if you have a "firebird" hatch which is found on the firebird and formula... That hatch is molded and spoiler is not replaceable. So I bought a whole new hatch... actuall i had a hatch with no glass shipped and then i bought new glass to have installed in it. The firehawk spoilers and t/a spoiler all use the same hatch...
as for closing the gap a couple thing to look at... if you take the headlight cover off there are 3 adjustments there. if you loosen all 3 you can play with it... once loosen it will make more sense. you will need a very small torq head to loosen them up.. after you have adjusted tighten back down and lay the headlight cover on top... don't worry about screwing it back in... then lower the hood slowly... and check for clearance. Then adjust as needed.
one thing you should know is the headlights open at an angle. so there will be some over lap of the headligth cover and the inside lipe of the fender.... I"ll see about taking some pics of all teh lines on my car to give you some ideas... also one thing you will notice... which i've failed to mention is you hood might not seem to fit right... thats because your hood stops aren't touching... you will need to get a set of channel locks or something and bend your current brackets upwards... if you replaced these props to you i'm doing mine later but i made them fit for now. the hood stops really do make a difference in the way the hood fits...
