what are the differences between 2001 and 2002 OS?? V8 F-Body
Old 10-08-2005, 09:43 PM
soundengineer's Avatar
Default what are the differences between 2001 and 2002 OS?? V8 F-Body
In a V8 F-body...
was there anything different in the OS...
meaning did they add anything or change anything other than the data in he tables??
like my example fo a change would be from 2000-2001 the removed the secondary VE, they added some tables in the complex cylinder charge area...
are there any benefits to updating from a 2001 OS to a 2002 OS (and obviously plugging back in your 2001 data in all the fields and tables)
just curious cause I'm already upgrading cars fro 2000 OS to 2001 OS... and just wanted to know if there ould be any benefits to upgrade to a 2001 OS
Old 10-09-2005, 03:01 AM
slow's Avatar
Were there any hardware changes for 2002 vs 2001?
I haven't compared the 2 tunes, as hptuners does not have a compare feature, but they should be similar, as the hardware for those 2 years are identical as far as i know, same cam, injectors, ect.
Ryan
Old 10-10-2005, 09:50 PM
I did the OS compare...I have HP Tuners 2.0..I am a beta tester...
heres the list of differences..
Code:
Main File   : 2001 M6 V8 F-Body.bin
Compare File: 2002 M6 V8 F-Body.bin
Main File Parameters   : 496
Compare File Parameters: 494
Parameters Compared: 488
Differences : 4
Similarities: 484
Engine
  Idle
    Idle Airflow
      Throttle Follower
        Throttle Follower Delay Time vs. Speed (In Gear)      10 of 18 cells
Engine Diagnostics
  General
    MAF Sensor
      Maximum Delta Airflow - P0101 Error            11 of 11 cells
    MAP Sensor
      P0106 Error MAP Calculated Max            38 of 77 cells
      P0106 Error MAP Calculated Min            64 of 77 cells
Old 10-10-2005, 10:55 PM
slow's Avatar
Thanks.
I don't have any compare tools I'm looking forward to seeing the new compare feature
Ryan
Old 10-11-2005, 11:55 PM
Phoenix 5.7's Avatar
im lookin foward to everything. 2.0 looks to be a beast with the features
Quick Reply: what are the differences between 2001 and 2002 OS?? V8 F-Body
