Does anyone make a graphite head
Hmmm...anyone know anything about the mls gaskets leaking with the 5.7 heads with notches in them? Not sure I should even bother putting them on. I have a set of 5.3's that I haven't finished the port work on, so these were going to be temporary. Guess they may be really temporary.
Learned something new (filed in archive).
But Brian, if the purpose of the notch was to remove heat, why did they do away with it after 2000?
As far as filling the notches, quite a few members here are running welded up notches with no issues. Of course a bandaged head does have limits.
Originally Posted by Brian Tooley
Do not use MLS gaskets on heads with notches
Do not weld the notches shut on heads, it removes the heat treat from the heads and then blows gaskets anyway.
Fel Pro makes a 6.0 graphite gasket 9199PT
GM makes a 6.0 graphite gasket 12558936
Hope this helps
Hope this helps
