Question about main caps
Old 10-09-2005, 06:32 PM
Fad2blk_98's Avatar
Default Question about main caps
I had a spun rod bearing so I had to pull the motor apart. After getting everything fixed it was seen that the main caps do not go back in flush. My question is, are you supposed to replace those bolts & could that be the reason the caps are not going back in right?
Any help is appreciated.
Old 10-10-2005, 11:16 AM
Fad2blk_98's Avatar
ttt any help here please?
Old 10-10-2005, 12:03 PM
JoeyGC5's Avatar
Original main caps? Give MC a call 913-789-9888
Old 10-10-2005, 12:10 PM
Fad2blk_98's Avatar
Yep they are the originals. They were fine when they came out, and I put them back on to take to the machine shop & they fit fine then too. I called TSP and was told it shouldn't matter which bolts are used as far as fitting goes, but I will probably replace them anyway. Still unsure as to why they wouldn't fit and sit flush though?
Old 10-10-2005, 12:18 PM
vtanju's Avatar
of the 5 main caps, which ones dont fit properly? or is it all of them?
Old 10-10-2005, 01:33 PM
Fad2blk_98's Avatar
Actually I'm not positive. I was just told there were one's that were not fitting. Is there something to check if it is just 1 or 2?
Old 10-10-2005, 06:57 PM
n2ojunkie's Avatar
Well first did they do any work to them? like line bore the mains? if not did they put them all back in the same spot? did they turn any around (front to back)? there could be alot of little things like that, that could be easy to screw up and also to fix.
Old 10-12-2005, 03:41 PM
vtanju's Avatar
the marking 5 on the 5th main cap is supposed to be on the opposite side as 1,2,3,4 markings on the other caps when installed. maybe this might be you problem.
Old 10-12-2005, 08:32 PM
Paulz2820's Avatar
one of the dumber things GM did with this motor. why don't they just put it facing the same way as all the others?
