New motor, TCS wont work???
Old 10-09-2005, 11:05 PM
stangkillerss's Avatar
Default New motor, TCS wont work???
Ok, blew the motor up in my car, put a used motor in it, now the tcs wont work. Same old computer, its the auto, 98 car. What should i look for first for problems, plug ins, new pcm, what???
Old 10-09-2005, 11:33 PM
strokedls1's Avatar
Check that the ground up by the fuse box under the hood is connected. It is used for the tcs system. I forgot it when installing a new motor in my car a while back, and when I grounded it the traction system worked again.
Old 10-09-2005, 11:34 PM
Brandon Boomhauer's Avatar
check to see if its plugged in on the passenger side...
Old 10-10-2005, 12:16 AM
kpowr82's Avatar
Does the used motor have a decent sized cam? If it does, you need to adjust your min and max MAP sensor values by about 30% (assuming you have no vaccuum leaks in the intake). Actually I should have asked if you're throwing a P0106 code. If you are, then that is why your TCS is acting erratic.
Old 10-10-2005, 09:39 AM
thanks guys, i will try all this, the new motor doesnt have a aftermarket cam in it, i will try the ground wire and see if its plugged in on the passanger side.
Old 10-16-2005, 05:37 PM
jjs316's Avatar
Where exactly does it plug in?
