Drag Racing Tech
what kind of light weight batteries??
Old 10-10-2005, 04:36 PM
8 second mod
Noyzee's Avatar
Thumbs up what kind of light weight batteries??
what is everyone using for a light weight battery?
what does it way? is it side post? top post? or both?
thanks.
Old 10-10-2005, 05:03 PM
GM Muscle's Avatar
Hey Brad, I'm running a Hawker PC680 for gotbatteries.com . Thing has been working awesome all summer, only weighs 13lbs.
Old 10-10-2005, 05:43 PM
8 second mod
Noyzee's Avatar
cool, what size is it?
i will try to find it on the web site.
Old 10-10-2005, 05:45 PM
Mark98SS's Avatar
Does it work OK with the stock alternator?
Old 10-10-2005, 05:46 PM
8 second mod
Noyzee's Avatar
what he said? and also, can it be charged with a regular charger?
and do they have a phone # lol
cant order it online.
Old 10-10-2005, 05:56 PM
Mark98SS's Avatar
Yeah, worried about pumping too many amps into a small battery
Old 10-10-2005, 06:44 PM
GM Muscle's Avatar
I knwo alot of guys use them with stock Alts no problem, I've been using mine with both ASP underdrive pullies. I havn't had to put a charger on it yet this year, I don't run any fans or heaters with the car off in the lanes though. I believe that any SLA charger will work.
Here's the one I have.
http://www.gotbatteries.com/items.as...SL105/37L105S5
Here's a list of all the hawkers and their specs.
http://www.gotbatteries.com/products...es/Odyssey.asp
BTW: The PC925 is a great option too, it's 25lbs though.
Old 10-10-2005, 07:52 PM
nuzee's Avatar
I got the exact same one as GM Muscle but the name is different, Odyssey pc680. I got it off of an ebay vendor.
Old 10-11-2005, 08:02 AM
NHRATA01's Avatar
I've been using the Dynabatt this season with the Thunder holder. Hasn't given me any problems. I even killed it once, trickle charged it overnight and it was good to go again.
Old 10-11-2005, 09:36 AM
jay_99z's Avatar
I run this one too. http://www.gotbatteries.com/items.as...SL105/37L105S5
Same as the Dynabat for half the cost.
Old 10-11-2005, 10:13 AM
TWS
TWS's Avatar
I'm running a Hawker Odessy in my '02. Cranks the car and works fine when charged, but it does not have much of a reserve and also will not hold enough charge to crank if the car sits for a couple weeks. My '02 is a semi garage queen, so it sits sometimes for 2-3 weeks without being driven. I have to remember to put the trickle charger on it a few hours in advance of driving it, otherwise when i jump in the starter solenoid just clicks.
Old 10-11-2005, 10:26 AM
Restricted User
CAT3's Avatar
Noyzee, I am running the same as GMMuscle as well, and got mine off ebay motors, typed in search pc680, ordered from the buy now, and got it in 3 days. Easy install, no adapters really needed, however I am buying them as posted on their ad. For basic install, unbolt terminals from present batt. remove the bolts from the rubber boots, and install bootless terminals using the allen head screws provided with battery. Then, I used a 1.25" (1" is NHRA legal but I didnt want tech having a fit) wide flat aluminum from Home Depot, bent into same shape as GMM, bolted down using stock hold down bolt, and drilled in one self tapping screw on the vertical riser. I use a stock alt. ASP UDP, I run my car as a daily driver (well was until the A4 **** the clutches again ), stock stereo, AC, Lights, and I power my laptop from an inverter as well as wideband, occasionally a manual low speed fan switch with the car in the pits. NO ISSUES YET. I love it, small, compact, lighter by a long shot. Like I said, I will order the terminal lugs, they screw into the batt. and then you can use the stock hardware with rubber boots. Good luck and you'll enjoy it.
Old 10-11-2005, 02:44 PM
8 second mod
Noyzee's Avatar
i ordered one today. for now im going to try to rig it into my bmr rear batt mount, if it wont fit, i will make my own at work.
anything to loose some weight!!
thanks for the imput.
Old 10-11-2005, 06:17 PM
GM Muscle's Avatar
Brad, I've read that a few people have had trouble starting their cars with the PC680 mounted in the rear. I know that Mighty Mouse had been running one in the rear no problems though.
Old 10-12-2005, 08:50 AM
8 second mod
Noyzee's Avatar
****, well, i hope it works out.
i do have some very large cables, and i will just have to keep it charged very well.
