Car Wont Start
Car Wont Start
95 LT1
CAR WILL NOT START JUST CRANK , RAN FINE CHANGED RAD. HOSE ALRM IS MAKING A CLICKING NOISE IN THE BLACK BOX UNDER THE DASH, DOES AND HOW DO YOU RESET, (BLACK WIDOW) BRAND THE VALET SWITCH IS BROKE, I REPLACED THE COIL AND STILL NOTHING IT IS GETTING FUEL, ANY ANSWERS WOULD BE APPRECIATED
Originally Posted by vulgardisplayofpower
95 LT1
ok...firt off..lose the caps lock
second..holy run on sentence batman.....
changed radiatior hose.....did you disconnect any wires when you were doing this...
second if the valet switch is broke then this might be your problem
try this link....
http://www.blackwidowsecurity.com/faq.htm
I would find out what that black box is...which it is probably the alarm stuff...
