What the @#$^ was GM thinking?
Old 10-11-2005, 11:51 AM
Whisper's Avatar
Default What the @#$^ was GM thinking?
When they designed the damn door panels to where you cant change out speakers without removing the ENTIRE ******* DOOR PANEL! I finally got my SPS-170as thinking this was going to be only moderately time consuming. Big damn surprise.
This is quite a useless post but I just need a place to vent before i go on a mudering spree for ignorant design. How hard are these panels to remove and how many tiny pieces of damn plastic parts do i have to worry about flying out upon removal?
Old 10-11-2005, 12:16 PM
Copy & Paste Moderator
VIP1's Avatar
The are very easy to remove.
Check out this window motor replacement thread from the FAQ to see how to remove the panels:
https://ls1tech.com/forums/showpost....1&postcount=18
Old 10-11-2005, 01:24 PM
Rescue Ranger's Avatar
One thing though, once you take em' off youll realize how easy it is. Just take your time and do everything slowly.. don't force anything.
Every single car i've ever done I had to remove door panels, rear panels for rear speakers, and door sills to run wire properly. It may seem like more work up front, but in reality, taking everything apart saves time because it lets you do everything right.
Old 10-11-2005, 07:12 PM
HiTechGent's Avatar
Ranger has it right. The door panel was a pain to take off the first time I tried (couldn't find the screw hidden under the armrest at first). But once you know how, it comes off in 5 or 10 minutes.
Old 10-11-2005, 07:17 PM
Duffster's Avatar
REMOVE the black plastic corner (by the mirror) BEFORE starting! ! ! Those suckers snap easily! ! !
Old 10-11-2005, 09:19 PM
Whisper's Avatar
Thanks for the info and insight, guys.
Old 10-12-2005, 01:02 PM
maddboost's Avatar
The majority of vehicles require the entire door panel to be removed for speaker replacement.
Old 10-12-2005, 04:16 PM
Luna's Avatar
I only had to get it loose to change mine out
Old 10-12-2005, 08:48 PM
JackZ28's Avatar
Maybe they didn't want you to remove them.
Old 10-12-2005, 09:29 PM
Richiec77's Avatar
Yup. And that GM Door panel is one of the easiest to remove. You should see some other cars and how the panel has to come off. You'd praise this Panel for how easy it comes off.
Old 10-13-2005, 06:01 AM
HiTechGent's Avatar
I agree. I've had occassionly needed to remove the door panels of a few of my previous automobiles. And my SS is by far the easiest to disassemble and reassemble.
