Question about head bolts.
Old 10-11-2005, 10:29 PM
My 1st Love's Avatar
Default Question about head bolts.
I am going to torque down my head bolts and am a little unclear about something. A book I have says to crank the long bolts 22lbs, 76 degrees, 76 degrees. The short bolts on the ends get 22lbs and 34 degrees. But the book was wrong about the oil pump cover bolts when it said 18 foot pounds instead of 106in lbs. Ls1howto.com says 22, 90, 90 for long and 22, 50 for small. What is correct?
Old 10-12-2005, 05:52 PM
somebody knows this, come now.....
Old 10-12-2005, 05:57 PM
vtanju's Avatar
its 22+76+76 for the long bolts and 22+76+34 for the small ones. dont forget this is for brand new bolts. if you are reusing the old bolts i would say and another 5degrees.
Old 10-12-2005, 06:10 PM
Taspeed's Avatar
That is the correct torque sequence. I have been using it for years without issue. I would NOT re-use head bolts. Its not worth the consequence.
Think about a rubber band....you can stretch it out as far as it will go. Right before it breaks it has its most tension and strength. This is what the torque to yeild bolts are designed to do. Torque it to its limit right before it breaks and hold it there. It is a fact that it has its strongest holding point there. Think back now to the rubber band. When you stretch it as far as you can...then let off and do it again. Usually it will break. I wouldn't want that for the trouble it would cause getting it out of the block or blowing the head gasket while under heavy load.
Old 10-12-2005, 06:27 PM
I already have a new bolt set from thunder racing. I wouldn't ever use old bolts after I just spent the money on AFR 205's.
Old 10-12-2005, 06:31 PM
vtanju's Avatar
the bolts you bought from thunder are they ARP or OEM style, because if they are ARP dont follow OEM specs. ARP straight with a torque wrench just torque anywhere between 95Nm to 105Nm depending on your application. if you are going to use NOS then torque 105Nm.
Old 10-12-2005, 06:49 PM
They are OEM, I wouldn't use arp unless they were studs.
Old 10-12-2005, 07:45 PM
The people at Gearchatter have it listed in the torque specs area to do the 22,90,90 long and 22, 90, 50 short. WTF.... I would think that there is the right way to do it and there can't be two right ways.
Old 10-12-2005, 08:19 PM
TAQuickness's Avatar
why don't you go buy a shop manual and verify it?
Old 10-12-2005, 08:54 PM
Well that is the great thing about this website. I can save the money and ask some of the wonderful people here. Some comments are helpful, others "are not".
Old 10-12-2005, 10:01 PM
mrr23's Avatar
i did the 22 ft-lbs 90-90 and 22 ft-lbs 90-50 as shown here http://www.lastofthebreed.com/Servic...orqueGuide.htm
Old 10-12-2005, 10:13 PM
Lady Redhawk's Avatar
Location: sojourning....looking for my city whose builder and maker is God.
Yep, those are GM's torque specs for their TTY bolts. (wish I used those bolts )
Old 10-13-2005, 10:36 AM
danf1000's Avatar
the torque to yield means this...
torque until there is permanent stretch (past the yield point, or point where further increased loading would cause permanent deformation)
this point is before the actual break point, but after the bolt has actually stretched some distance. the bolts removed will be slightly longer than before.
this does not work for materials that are brittle, only ductile, or stretchable materials
