Thinking about the T-rex.....
I have been reading about Thunder Racing's T-Rex camshaft. That seems like one mean cam! I am thinking about upgrading to that beast, but I really do not want to go through the hassle of having to fly-cut my pistons. I have the Patriot stage II heads with the 59cc chambers. Does anyone know if that cam would work with my setup without piston modification? Also, if this cam is too high lift, in your guy's opinions, what would be the HIGHEST lift cam I should go with 59cc chambers? And what duration and LSA would you recommend? I am looking to MAX out my cam profile..
u could do the search thing and all that info stuff, but I would ask gunnar at. gunnar@patriot-performance.com
hope this helps.
fuerzaws6
hope this helps.
fuerzaws6
1. I highly doubt the T-rex will fit
2. You question about the highest lift cam that will fit won't get you anywhere. There is a lot more to it than lift. It's a matter of WHEN the vavle is lifted, and for how long, you don't run into PTV issues at max lift. Well, hopefully not.
