Is anyone using a Mcleod clutch line?
Old 10-12-2005, 10:46 PM
25thhawk's Avatar
Default Is anyone using a Mcleod clutch line?
Saw it in an old issue of GM high tech. It is a replacement for the line from the master to the slave. Has anyone tried using it? Is it any better than the stock one or is it just a stock one with the restriction drilled out?
Thanks
Ryan
Old 10-13-2005, 08:48 PM
DanZ28's Avatar
I undestand it has a larger I.D. So I guess it moves more fluid. Mcleod also has a new slave out as well.
Old 10-15-2005, 04:27 PM
rush7's Avatar
does anyone have the link to order this out of their online catalog? I cannot find it.
Old 10-17-2005, 11:22 AM
LS1TECH Sponsor
Steve Burger's Avatar
YOu will need to call them. I just sold mine when I went TH350. It did workand does flow a lot more fluid.
Quick Reply: Is anyone using a Mcleod clutch line?
