Bleeding the WHOLE clutch system on the car?
My fluid is darker because it got heated up from my LT's and I want to change out all the fluid so that everything will have clean fluid in it. With the mity vac, how do I go about doing this. Do I set up the vac normally and also run a hose from the bleeder valve to a can of new brake fluid? That way it sucks fluid upthrough the resivore from the bleeder vavle, or am I incorrect? Need this done asap, so any help or detailed steps on how to do it are greatly appreciated.
Thanks
Robert
Thanks
Robert
There are some instructions in this thread on how to bleed/flush the hydraulics.
https://ls1tech.com/forums/manual-transmission/346299-hydraulics-question.html
