i need help installing my ground effect
hi i just got my ground effects and i dont have an idea on how to install them, my firebird did not brought them so i bought a pair in ebay for 150.00 any help and info would be appreciated thanks in advance to all of yous.
ok jack up your car, take off the tires from the side your working on. Dont forget to chalk your other tires. Now hold your ground effect up to where you want it, there shoudl already be some holes in the sides where the wheels go. drill some new holes into your fender to hold the effects up. repeat the process on the other side. once all the corners are supported there will be some sag in the middle. you can use some 3m double sided automotive tap to support them or you can go get some automotive gloop and use that. some ground effects have little clips all the way down the sides of the drivers and passengers effects. those will require you to drill holes. anyways, if you dont feel confident with a drill then i suggest taking it in, or finding somone you trust.
This might give you an idea along with the post above.
http://www.wingswest.com/pdf/98%2D01...0install%2Epdf
Don't forget the adhesion promoter.
