Oil Leak From Bellhousing-m6
Old 10-15-2005, 02:53 PM
paulcars's Avatar
Default Oil Leak From Bellhousing-m6
I have a small amount of reddish oily odorless fluid leaking from the bellhousing area. Is this transmission fluid or hydraulic fluid from the hydraulic throw out bearing? If it is tranny fluid do you think it would get to the clutch? Have a new Textralia clutch and do not want to ruin it. Thanks.
Old 10-15-2005, 06:52 PM
618HAWK's Avatar
Red is from the trans, clear is form the slave. Either one is bad news for the clutch. Best to get it corrected ASAP. I would not drive it, especially if it is a new clutch that is in there.
Quick Reply: Oil Leak From Bellhousing-m6
