Spray shuts off randomly...why?
Here is my setup:
'96 Z28
Bolt-ons
Strange 3.73s
3200 stall, CPT 4L60E
MSD Digital 6
MSD Digital Window Switch
NX GM EFI kit
NX GenX2 upgrade
Racetronix 255lph fuel pump
NGK TR6s @ .035
Bottle is mounted correctly (blowdown fitting direction is up, bottle is angled properly)
Shark Nozzle in stock IAT sensor location
MSD retarding timing 2 degrees (100 shot), activated by WOT switch
When spraying, it randomly shuts off....mostly in third gear. Actually, I'm pretty sure it's ONLY in third gear. My friend is also having this same problem with his car, but he is using a BMN window switch with the same N2O kit.
I was at the track Wednesday, and I sprayed in top of first, it sprayed all through second, then in third gear, it shut off, and then came back on before the traps...I gained 8mph in the 1/8th and 7mph in the 1/4 from a 100 shot because of this.
My window switch is set for 3000-5700.
Any idea what would cause it to shut off randomly like this? It only happens sometimes...bottle pressure is good and it happens when the bottle is full too....
*Edit - FYI I did not use the FPSS with the GenX2
'96 Z28
Bolt-ons
Strange 3.73s
MSD Digital 6
NX GM EFI kit
NX GenX2 upgrade
NGK TR6s @ .035
Check the connection for the MSD off the ECU. I used the tap supplied with the MSD unit and at high speeds it would loose contact. I ended up soldering the connection and have not has any problems since.
Hope this helps...
Hope this helps...
Originally Posted by MattZ28
Is it common for MSD Digital window switches to be defective?
I would assume it is going through a relay, correct? If you don't have a relay in there, make sure you get one. With that said, check for a loose ground. If ALL grounds are good, check for any wire connections. The connections might be overheating causing a bad connection.
I'm pretty sure the MSD is getting its signal from the Digital 6....it's been awhile.
And yes, it's through a relay. All grounds look good and connections seem nice and tight
i have the same problem!!! it happens with my msd digital window switch too!!!! almsot always in 3rd! i think it is my connection to the tach wire though...I would check that out before you test anything else
FYI guys I got rid of the Digital MSD. Sent it back to Jeg's for a full refund, and got the analog MSD like ^^that guy did. Made 4 passes at the track last night and all is good
Glad to hear that. I am also glad I ran across this thread. i had the same problem the last time I used the juice. But it seemed like it came on then shut off pretty quickly.
I have no FPSS and I use the MSD window with the pills. I'm wondering if its a bad connection at the ecu. I know my ground is good, but something else is going on.
Luckly it happened when I tried it on the street and not the track. But I need to get this adressed before next season.
Its got to be a connection problem I think.
Robert
