!ACing right now
!ACing right now
I have removed everything so far except the damn compressor, i have taken like 6 bolts from it and it still does not go off, i can see another 2 bolts holding it, but there is no way i can fit a socket.. it's like between the bracket that hold it and the compressor itself..
Can anyone give me some advice here?
that's damn weird then, because i took them all... even some bracket bolts and its hard on it.
it still has the rear line connected, but the radiator is off, so the other side is free.... could that thing be the problem?
Bah anyway i will go check out now. Thanks..
Ohm anyone know how much do the Swaybar Brackets weight?
Most people take everything out at once. But a large vacume cap or anything that will seal it off good will work. If nothing else duct tape will work fine, but may not look so good.
Every pound counts!
Anyone else that has removed the AC front components, What did you used to seal the HVAC line that is left open?
Originally Posted by Loudmouth LS1
Which one is that, you talkin about the one where it connected into the big box on the passenger side? If so, does it need to be sealed, cuz I didn't seal mine, just left it open, I plan on pulling that all out when I pull the dash for the 10 point install, just wondering why it would need to be sealed up?
Right now i just left it with some tape.. but i will fabric something to seal it.. i dont think i will ever remove that thing unless i win the lottery or something.. but sealing all the other **** is a mess....
well.. this was a fun day.. !AC !Front Swaybar.. the car feels somewhat more even...
Originally Posted by SPEEDYws6
Cause if you ever wanted to recharge the system the moisture that will get inside from it not being sealed could cause problems. If that will never happen, don't worry about it. If recharging is a possiblity seal it up.
