Qtp Hv Oil Pump
Old 10-16-2005, 04:17 PM
Firehawk441's Avatar
Default Qtp Hv Oil Pump
I just fired up and broke in the new engine. The engine now has 165 miles on it.Oil pressure is 55 PSI @ idle and 75 PSI @ W.O.T. This is the first pump that accually works better than stock. I have used other so called ported pumps in the past only to be dissapointed with the results. Hope this helps other engine biulders out there.
Old 10-16-2005, 07:09 PM
vettenuts's Avatar
QTP was at Corvettes at Carlise in August. I looked this pump over as well as their 2 piece timing cover. Both appear to be very high quality items, especially the 2 piece cover.
Which spring did you use on the bypass?
Old 10-17-2005, 06:23 PM
Order 66's Avatar
Im going to get one of the 2 piece cover and pumps shortly when i get my cam put in.
Old 10-17-2005, 06:58 PM
pewter 01 SS's Avatar
HOW MUCH DOES THIS OIL PUMP COST??
Old 10-17-2005, 09:09 PM
The pump comes with a high pressure spring already installed and a standard spring in the box. I used the high pressure spring in the 402 I posted the figures on. I previously tried this pump in a stock bottom end with the high pressure spring. 60 PSI @ idle and 80 plus @ W.O.T. I recommend the standard spring in this application. Price for the pump was $175.00 & $425.00 for the two piece timing cover. The cover comes in quite handy when changing cams as often as I do.
Old 10-17-2005, 10:43 PM
1CAMWNDR's Avatar
Is this oil pump compatible with the stock timing cover, or do you have to also lay down the dough for their 2-piece cover?
Old 10-18-2005, 03:02 AM
DONAIMIAN's Avatar
it is, but it has to be clearenced.
Old 10-18-2005, 05:56 AM
what type of clearence issues are there??
Old 10-18-2005, 08:22 AM
ninobrn99's Avatar
the 2 piece timing cover would come in real hand right about now!
Old 10-18-2005, 01:00 PM
DONAIMIAN's Avatar
talk to low n slo, I belive hes the one that did it, or just do a search under her name.
Old 10-19-2005, 06:24 PM
I can't say for sure. I bought both the cover and the pump together.
