No Rev Limiter
Old 10-16-2005, 09:59 PM
Taphee6's Avatar
Default No Rev Limiter
My Rev Limiter is set at 6800 and last night at the track I was hitting 7100 and did not bump the rev limiter. This was in 1,2,and 3rd gears. I had to back off the gas or blow the motor. How can this be???
Thanks in advance
Old 10-16-2005, 10:04 PM
dcdime's Avatar
If you are using your stock tack, it could be off a few hundred RPMs
Old 10-16-2005, 10:06 PM
soundengineer's Avatar
what table are you looking at for the rev limiter
should be cutoff rpm vs gear...and your resume must be less than your cutoff
Taphee6's Avatar
Default Tack
I have a stock tack and an Autometer. Both are accurate when I checked the computer RPM with HP tuners.
Old 10-16-2005, 10:08 PM
Taphee6's Avatar
Default Cutoff
You got it. I just pulled up the file and last time it was tuned the shop changed the cutoff. It was set at 7000. I should have looked before shooting off at the keyboard.
Thanks Guys
Old 10-16-2005, 10:24 PM
LS1TECH Sponsor
foff667's Avatar
in hptuners there are like 4 different limiters make sure your modifying the correct ones.
Old 10-16-2005, 10:47 PM
SmokingWS6's Avatar
m6 or a4?
