Suspension & Brakes - Front sits higher then back after shocks/springs
FuzzyLS1
10-16-2005, 10:38 PM
It's been a few months since I got some shocks and springs installed. The rear sits real nice, but the front is probally about an inch or so higher.
What can be done or checked on (short of cutting the springs) to get the front sitting lower?
Big picture: http://putfile.com/pic.php?pic=10/28822334396.jpg&s=x10
Marc '99T/A
10-16-2005, 10:48 PM
If I remember, there is a rubber boot that the front springs sit on. What about taking that off and wrapping a piece of hose around the bottom coil?
erikthegoalie
10-18-2005, 05:34 AM
hey dude...its a bad idea to remove anything and replace it with a hose....if you want it lower in the front do it right..either new spring choice (try eibach sportlines) or coil overs, that way you can set your desired hieght on any given day....check out ground force...they are nice and inexpensive
taintedmeat
10-18-2005, 08:07 AM
Fuzzy:
Just a quick question for you. I have the same wheel and tire setup you do, same backspacing and size on the back. I was thinking about putting some new springs on my car when I do the shocks, but I already get some rubbing out of the back. If you already had rubbing, which I'm assuming you did since those are 17x11's on the back with like the biggest tire you can put on them(Eagle F1), did your rubbing get any worse after the install? :confused: Thanks.
OneMeanZ
10-18-2005, 10:25 AM
What shock/spring combo are you running?
FuzzyLS1
10-18-2005, 08:08 PM
Koni SA and H&R springs.
Just a quick question for you. I have the same wheel and tire setup you do, same backspacing and size on the back. I was thinking about putting some new springs on my car when I do the shocks, but I already get some rubbing out of the back. If you already had rubbing, which I'm assuming you did since those are 17x11's on the back with like the biggest tire you can put on them(Eagle F1), did your rubbing get any worse after the install? Thanks.
They only really rub when there is a passenger in any seat or in really hard turns. We did some BFH'ing when we put the tires on with stock ride height, but none after it was lowered. I did put an adj. phb on it also.
FuzzyLS1
10-24-2005, 03:22 PM
Any other ideas? I am using Koni Single Adjustable shocks and H&R Stage 2 springs.
I did not install these springs, is there anything to check to make sure they are seated correctly? Can they even be seated incorrectly?
Screamin_Z
10-24-2005, 04:31 PM
My Hotchkis springs are the same way. I would love to know what causes this. :eek2:
mcowart
10-26-2005, 01:40 PM
so i had this problem..and the only solution i could find was to get the front springs cut..The shop took off 1.5 coils i believe on my eibachs....it sits perfectly now and handles much better...if u did the hose mod in the back if u dont want to cut the springs u can put that rubber piece back..
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
