Megasquirt Setups and Mafless
Does the MS system allow you to run MAFless as well as o2less. Who has this setup, other then parish? Thinking about moving over so I can get rid of the MAF and o2s!
Tiff is running it on her car too. If you want to see it first hand, we can give you a tour of her car and the system.
But yes, it runs speed density, mafless -- or with a MAF if you want, currently only a "Ford style" or voltage mapped vs. GM's frequency mapped. It also supports "Alpha-N" tuning, which is basically rpm vs. throttle fueling. You COULD run w/o an O2 sensor, once you establish your VE table -- but its intended to work with 1 or 2 wideband O2 sensor(s). Works great out of the box with the commonly available units, like the Innovative LC1/LM1, TechEdge, AEM, etc. but you can calibrate it to anything.
