Head CC chart
Old 10-18-2005, 01:24 PM
Restricted User
NOSjohn's Avatar
Default Head CC chart
Someone posted a long hand "chart" of LSx head cc compressiopn ratios. I thought I copied it but cant find it. Anyone have the post or results? It is much easier than calculating all the results. Thanks in advance!
Old 10-18-2005, 02:19 PM
ssheets's Avatar
Linky
Here is a list of a few casting #'s:
853 97-00 aluminum 5.7
241 01-03 aluminum 5.7
243 LS6 aluminum 5.7
852 and 706 99 and up 4.8-5.3 truck heads
873 99-00 LQ4 6.0 iron heads
317 01 and up LQ4 6.0 aluminum heads
035 02 and up LQ9 6.0 aluminum heads
Even more info:
Casting Number 241
Head: 1997+ LS1 5.7 Litre Passenger Car
Material: Aluminimum
Part Number:
12559853 (1997-98)
12559853 (1999-00) (not sure why same PN)
12564241 (2001-03)
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Casting Number 243
Head: 2001 LS6 5.7 Litre Passenger Car
Part Number:
12564243
Combustion Chamber Volume: 64.45cc
Compression Ratio: 10.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Casting Number 706
Head: 1999+ LR4 4.8 Litre Truck
1999+ LM4 /LM7 5.3 Litre Truck
Part Number:
12559852
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Valve Diameter: 1.89 inches
Casting Number 373
Head: 1999-2000 LQ4 6.0 Litre Truck
Material: Cast Iron
Part Number:
12561873
Combustion Chamber Volume: 71.06cc
Casting Number 317
Head: 2001+ LQ4 6.0 Litre Truck
Part Number:
12572035
Compression Ratio: 10:1
Old 10-18-2005, 02:23 PM
Restricted User
NOSjohn's Avatar
Yes, that is a partial...THANKS! However, I think he also did a list of the particular heads if they were milled "x" amount with the end result for compression differences. I will search his name.
