what is the best way to smooth out a stock intake to paint it
Originally Posted by ArcticZ28
In that order?
I sanded off the casting marks with 80 grit, then used 180 on all of the tubes. I then sprayed it with high build primer,
sanded it with around 300 until it was really smooth, then sprayed it with a black poly primer with a hardener.
Wet sanded that with 600, then sprayed 2 coats of basecoat, then 3 of clear. I like how it turned out..
You dont need to do the black poly primer i think, but the store i bought it from said it was more heat resistant.
thought id put in a few... be sure to take your time.
olly
olly
Originally Posted by stryker14
spray a high build primer and sand with 600 grit and you can get it smooth as a babies butt
Brett, will you quit posting that picture That is the perfect match for my FRC's and lid.
