Sponsored by: DashLynx
Camaros with true duals
Old 10-18-2005, 06:40 PM
Shirt_Ripper's Avatar
Default Camaros with true duals
I would like to see what the camaros look like from the rear that have true duals dumped at the axle. Ive never really paid attention to what they look like with no pipes back there.
Old 10-18-2005, 06:44 PM
The Great White Bat's Avatar
I have a z with true duals dumped and it looks pretty badass. I think that it obly looks good when the camaro has the ground effects. I will get you pic soon.
Old 10-18-2005, 07:32 PM
skippytheloon's Avatar
2 threads down..."my car! pics! looky" hehe, theres a pic there.
looks better to see turndowns under car or exit at the muffler like the mufflex, I'm not a fan of tips sticking out.
Old 10-18-2005, 07:35 PM
Rob Mobile's Avatar
go to www.LS1sounds.com and click on pics then scroll to where it says true duals. It also shows pics of cutouts. Very good pics over there.
Old 10-18-2005, 07:56 PM
tylerdj's Avatar
I'll see if I can get some pics of mine. I think it looks 1000X better w/out tips. I dunno, just kinda gives it a sportier look to me.
Old 10-18-2005, 08:46 PM
GM Muscle's Avatar
I think no tips looks alot better too. I don't think I'll ever go back to a regular cat back.
Old 10-18-2005, 09:52 PM
CrabhartLS1's Avatar
If only we could get side exits coming through the fender. probably more like through the door cause that can't happen.
Old 10-18-2005, 10:43 PM
say man, how much harder is it to not scrape that wings west front facia than the stocker gfx, like how much does it hang down at the nose? I likey
Old 10-18-2005, 11:02 PM
Ell Ess Won's Avatar
True Duals would be nice but I hate not being able to see tips. Can you tip them?
Old 10-18-2005, 11:21 PM
Trev_SS's Avatar
yes you can run them all the way back it just has to be under the axle so i would be very low, i have seen it on a car parked at speedtek
Old 10-18-2005, 11:36 PM
LSUxBlake's Avatar
You can run true duals over the axle.
Old 10-19-2005, 12:05 AM
2MuchRiceMakesMeSick's Avatar
You can run true duals over or under the axle. Over is better as far as filament.
I personally like the looks and sound of the turn downs with no tips
Old 10-19-2005, 05:50 PM
There was someone a few months back who made a custom true dual setup. Went from LT's through an X pipe, then over the axle, then into two magnaflow bullets, then lastly to a CME. Was the absolute cleanest thing i've ever seen.
Old 10-19-2005, 05:55 PM
catfSSh's Avatar
ive heard that only a 2.5'' true dual will fit over axel. and a 3'' dual wont. but i dont get this because most regular single crossflow catback setups are 3'' and fit over the axel on the right side so why not the left too?
Old 10-19-2005, 06:16 PM
GM Muscle's Avatar
Well, I had never ever scraped it on the street. However, it drags on decel at the track even with it modified and cut back acouple of inches. It took a hell of a hit last month and rolled the nose under the car, destroyed the GFX, nose supports, trans cooler, and so on.
Andrew
Old 10-19-2005, 10:17 PM
StangEaterSS's Avatar
here's mine. TSP x-pipe and dyno max bullets. dumped.
Old 10-20-2005, 09:40 AM
jwitt2's Avatar
i will post a pic of mine when i get home from school.
Old 10-20-2005, 04:37 PM
Swang's Avatar
Location: Hometown:Mount Carmel, IL Current: Las Vegas, NV
i just think they need something behind the axle if they dont have any ground effects. like Gm Muscle's looks really good but the Silver SS needs something, whether its ground effects or exhaust, it needs one of the two IMO. but hey, what do i know?
Old 10-20-2005, 05:47 PM
There is only one place where an exhaust pipe can go over the axle for some reason. I've been under there and there is a lot of crap right where the other axle would go over.
2.5" is just fine tho for a true dual over axle. It's not like you'll have a problem with velocity anyway.
Old 10-20-2005, 06:09 PM
ChevyZ28Thunder's Avatar
You can buy an upper panhard like this BMR. And go 3" over the axel
Here are some pics of my TD..
Quick Reply: Camaros with true duals
