Gears & Axles - what are your best 60ft on stock rear ends
mushroom281
10-18-2005, 08:07 PM
mine has a T/A cover auburn pro pos and a 3:73 gear and i am cutting 1.80 60 ft but need new tires and i don't want to put anything too sticky for fear of breaking my rear end
so what kind of 60's are you guys cutting on sticky tires and what have you done to your rear to make it stronger?
and what tires are you running
franny40
10-19-2005, 02:59 AM
1.7 on 18" nitto dr's. with stock rear and 2.73's
mushroom281
10-19-2005, 05:26 AM
anbody cutting 1.5's on a stocker?
TNTramair
10-19-2005, 08:27 AM
tryin doin that in a 6 speed car...:D
cablebandit
10-19-2005, 08:55 AM
1.54...hoping to go 1.4s
jay_99z
10-19-2005, 10:55 AM
1.56 for a little while with 3.73 10 bolt......
then posi went bye bye.
1.7 on 2.73s and Nittos with a Yank 3500
BIRDONNOS
10-19-2005, 01:56 PM
1.669 60ft leaving at 3000rpm and sprayin a 200 dry shot out of the hole on m/t 26x10 slicks. split the zexel diff all the way around the diff housing. car is a m6 with spec stage 3 clutch and 3.73's out back in the 10 bolt.
OctaneZ28
10-20-2005, 09:47 PM
1.651 on a 26x10x15 Hoosier slick and 2.73 gears. :)
formula305
10-20-2005, 11:57 PM
1.82 with an M6, stock 3.42's and ET Streets off a 6500 rpm launch with 400rwhp.
GM Muscle
10-21-2005, 06:28 AM
I believe my best has been a 1.43 so far. I did do a cover an axles though. Plenty of A4 10 bolts have held up to 1.40s on a regular basis. But I'm sure that there are plenty more that have not.
TNTramair
10-21-2005, 06:57 AM
:eek2: :eek2: 6500Rpm Launch????? wholy sheep sh*t!!! :hail: :hail:
COMNBYU
10-21-2005, 10:05 AM
My best with the stock 10 (big Auburn, Rich. 3.73's) with my old LT1 was a 1.63 spraying a 150 out of the gate.
Jon
redsscamaroboy
10-21-2005, 10:10 AM
1.61 motor,1.54 150 shot.
Stock everything back there.
Dave
TA TECH
10-23-2005, 12:16 PM
Mine just went! :bomb: with the same yester day! :(
OOOJOHN
10-23-2005, 12:54 PM
I have went 1.63 on 150 shot with 410s back there
On hoosier slicks 26X10X15
nikon1999
10-23-2005, 05:59 PM
1.69 60' 3.73's in a 10bolt. Yank ss3600
Wicked Z
10-23-2005, 06:13 PM
The quickest i have gone has been 1.4 on showroom stock suspension and stock rear end from the factory on a 16 inch et street.
Y2KSS
10-24-2005, 09:04 AM
I've been cutting high 1.4's but broke it Saturday night. I have not tore it down yet to see what actually broke though.
offaxis
10-25-2005, 08:26 AM
Best Ive seen is JFM (moderator) . He is still running his stock 10 bolt with 4.10 gears
He has done 1.40 60 fts on it. Thats on n/a power. I am sure If he was power adder the extra tq would bust that rear. Still killer 60 fts though
BIG_MIKE2005
10-25-2005, 08:44 AM
I have managed a 2.1-60' on bald street tires with completely stock rear end & suspension. My clutch also has several track passes & street races on it along with 70k miles. So I'm sure if I got some tires, suspension stuff, & clutch it would improve a bit. I'm also a M6 & launch at idle or 2k RPM, never any higher.
MARKSZ71
10-25-2005, 09:09 AM
1.55 with 323s
Derek98z
10-25-2005, 10:30 AM
1.81 with 3.42 gears and leaving off the rev limiter (6,800) on et streets. Lasted about 10 times.
Dragfast
10-26-2005, 02:14 PM
1.7 with 3.23's and 100% stock suspension on nitto 315/35/17's!
gator's 99TA
10-28-2005, 11:53 PM
my buddy just went 1.49 60' on the stock 10 bolt nearly full weight full stock wheels on et streets with 3.23 gears spraying out of the hole on a 4K stall converter. auto cars 1.4 is no problem. mn6 is another story.
BrianC98Z28
10-29-2005, 02:34 AM
1.65 on 275/40/17 nitto at 15psi. 3.42s and completely stock rearend including stock cover
2000blackSS
10-29-2005, 12:38 PM
i cut several 1.7's on the stock rear w/ spec stage 3 clutch, tnt 100 shot, bfg drag radials 17", 6 speed 3.42
1.75,1.76,1.78, i also cut a lot 1.8's
i was sprayin out of the hole
spec_j
11-01-2005, 07:05 PM
I cut 1.58-1.59 60's with a stock motor, stock rear and gears and stock suspended 4000 stall A4
urbanhunter44
11-01-2005, 09:50 PM
my bro is doing 1.7s with slicks burning them up through first gear through a 5-speed in his 89. It's a 10 bolt from an LT1 with a mini spool and a cover along with 3.73 cogs.
